DutchmenSport
Jan 28, 2015Explorer
I'm sure they can do that, and in my opinion, the price sounds reasonable. But you are looking at a 2001 vehicle in snow and salt road ridden Massachusetts? I think your situation would be the same as here in Indiana. If the undercarriage was not protected in 2001, the damage is already done by 14 years of winter salt and chemical corrosion from the roads. Even if the camper did not move when it snowed, it's probably still laden with rust that has already done deterioration to everything. Blast away the rust, and how much metal is left anyway. I think you're wasting your money if you do. Those types of protections are only worth while when the vehicle is new. Beside, unless he can completely remove everything and treat every minuscule spot, the existing rust will be under the treatment and will continue to spread anyway. Personally, I don't think there is any advantage to doing this. Someone else may have a different opinion.
38,767 PostsLatest Activity: Mar 11, 2026
