Mile_High
Sep 01, 2017Explorer
CA Traveler wrote:I don't find anything from Onan that supports your theory Bob, but Onan isn't real open about publishing the install manuals. What I do know, is the Engineers that designed my coach didn't see it necessary to do anything special for the 8000 QD, so I'm sure the OP will be fine not upgrading the wiring or transfer switch. I have the same 50amp rated lugs on my transfer switch that he does on his, and the wiring gauge, including the neutral, coming from the shoreline is the same going to the CB. I don't see where the generator wire size is any larger than the others either. My personal opinion is you are trying to prove a point that has no difference on the outcome.
Mike,
It's not theory - it's basic AC Circuits 101. Have you researched this to where you now understand the QD 8000 has a maximum 66A on the neutral and the RV 50A circuit has a maximum of 50A on the neutral?
