want-a-be wrote:
dougrainer wrote:
Once that model fails it is almost impossible to fix it. It has been discontinued by the Maker and even Tiffin does not have them. You can update to what Tiffin is currently using which is a much better Omnidirectional antenna. It auto scans 360 degrees instead of having to manually rotate with the wall remote. Doug
Do you have more information on the antenna you are referring to?
Model number and can it be hook up with the existing wiring!
Thanks
Sonny
Not at home. Call Tiffin and they will tell you the current brand/model. You use the existing Coax and control wires. If you take the old apart you wiull probably find it is rusted out from water intrusion. Doug
