klutchdust
Sep 29, 2014Explorer II
I am using the same splitter they use in the big box stores to run multiple tv's. It can split 4 times. When it powers up the plugs being used would normally light up unless it does
not get a signal. The rear TV is brand new Samsung. The TV in rear works but not always. When it isn't working the splitter output light for that wire is not lit. Always power to
the front tv. The splitter was recommended by another poster. I had another post going about what I was faced with, maybe i should have stuck with that posting. Basically i ran
50ft. of HDMI and replaced rear TV because the TV was not HDMI compatible and the DT receiver only had HDMI outputs.
38,782 PostsLatest Activity: Sep 10, 2026
