I have a 2007 Forest River Georgetown motorhome. The head light is mounted on plywood witch has rotted out . I was looking to find out if anyone has run across this problem and what the fix was . Only...
Replace the wood with plastic. You could probably find a couple of inexpensive (thick) cutting boards and cut them up into the shape you need. You'll never have a water issue again.
