j-d
Jan 29, 2015Explorer II
DaHose wrote:
Just spit ballin here, j-d. Jose
Me too, my friend. I removed manifolds on our '83 460 and I know they had no smog fittings. But I recall A.I.R. fittings in the rear of the heads.
I remember a MoPar 318 >> 360 swap where the 360 was later model and had little air holes under the exhaust ports of the heads. The manifolds I wanted to use didn't cover those holes. A friend called a speed shop and came back with this answer:
"Take Twenty-Penny Nails. Cut them in short pieces and pound them into those holes."
And so I did. Worked out just fine. But it was a 1971 vehicle, and only 1973 and later were being smog tested at the time. FL since eliminated its smog program.
But this makes me wonder if the EFI 460's use a similar design, where some ports in the heads don't get covered by the flange on Hedman Hedders.
Hey OP! Maybe check out FTE (Ford Truck Enthusiasts) or one of the Ford performance sites. Guys are putting 460's into Mustangs... And if I recall, a 460 can be hogged out to 534 or some huge number close to that.
