prstlk
Mar 18, 2014Explorer
Been there done this spend 10 bucks and try this, run a decent Gage wire like 10 from the neg. Side of the engine battery to all of the metal light frames on the coach front okay to split off from the 10 Gage to the frames as you get close. Be dawn sure your on the negative side of the battery. If all works you have a ground problem. If I'm right I can give you a $2 fix from there and tell you why if I'm wrong next time I'm through I will buy the beer j
38,782 PostsLatest Activity: Sep 10, 2026
