RacormanExplorerNov 30, 2015Headlight Assembly Filling With Water QuestionI’ve got a 2012 Itasca Class A and my right headlight assembly is slowly filling with condensation. I recently had my motor replaced by Ford and the dealership had to remove the entire front end panel...Show More
John_WayneExplorer IIDec 01, 2015When all else fails you can drill a small hole in the bottom of the lens to let the water out and air in.
Related ContentHow to adjust LED headlights?headlight assembly2000 F250 replacement headlight assembliesHeadlight mounting assemblyRemoving headlight assembly on Newmar KS DP
