- racer99ExplorerIf a Ford chassis ours is 2000 F-53--for replacement clips google AU-VE-CO #15940-RICH
- sc3283ExplorerDutch a 90 bounder has sealed beams not composite like an 02 Lincoln
Bounder, I'm at a loss how to research that info your needing - Dutchstar02ExplorerIt will still tell you where the headlight assembly was used. Mine is from a 2002 Lincoln LS.
- bounder23ExplorerI'm looking for the metal mounting bracket with the headlight buckets that have all the up and down adjustments and springs, mine is all rusted to the point that if I remove the headlight I might not be able to resecure it again.
- Dutchstar02ExplorerIf you look on the existing headlight there will be a DOT number. Google that number with DOT and it should bring up the proper replacement.
38,782 PostsLatest Activity: Sep 10, 2026
