Mote
Dec 02, 2015Explorer
DSDP Don wrote:
"Racorman".....Your type of headlights have twist lock bulb sockets, just like a car, with a foam or rubber gasket. You need to look behind the light and make sure the bulbs have their gaskets and they're locked properly in place.
This seems like a pretty good suggestion. Maybe since you just had the engine work done they didn't get the gasket back in place. How hard is it to pull the headlight assembly? Would be nice to be able to pull it out and use a hair dryer to dry out the inside of the headlight. Then put the bulb back in making sure it's sealed correctly. Hopefully that's all it needs.
38,782 PostsLatest Activity: Sep 10, 2026
