rgatijnet1
Dec 02, 2015Explorer III
You mentioned that ONLY your right headlight assembly is having this issue so it does not appear to be a design issue with the headlight. Check the bulb gasket and check the assembly for cracks. The headlights get very hot when lit so I would assume that if you just turned the light on during the day it should dry the water out in a few minutes.
Please elaborate on why Ford had to replace your V-10 engine on a fairly new coach.
38,782 PostsLatest Activity: Sep 10, 2026
