richardestaats's avatar
Sep 24, 2014
Headlight problem
I have a 1992 Bounder 35J diesel pusher on an Oshkosh Chassis.
When I turn on the headlights they come on fine, then after a
little while not long, they shut off. The markers and tail lights
and blinkers still work fine, but the headlights cycle on and
off causing a dangerous situation during nightime travel, or as
required during rain in most states. I have looked all over and
cannot find any fuse, relay or circuit breaker marked headlights.
Can anyone help me find one of those things, or tell me if you
have had the same problem and give me the quick fix for it?
  • Start with the ground and work back, but it does sound like a short in the circuit causing the breaker to cycle on and off. Try unplugging the passenger side headlight and see if it still does it. This will isolate 1/2 of the circuit.
