lafrentz
Mar 27, 2016Explorer
vegasfoodguy wrote:
I have Heart Freedom 15 inverter in 1999 Diplomat. When shore electric is hooked up, The batteries show dead. after driving for several hours, the inside remote shows the batteries dead. The built in charger-converter doesn't seem to be working. The hydrometer shows recharge, just below good. All 24 cells show the same (4_6v) none dead.
I know, kind of confusing.
Thanks,
Terry
well if the alternator is also not charging the batterys then don't be assuming your converter is bad till all solenoid's and relays etc are ruled out.It would be a stretch to assume your alternator charge solenoid and the converter both failed at the same time
38,782 PostsLatest Activity: Sep 02, 2026
