LouLawrence wrote:
I had to replace my current Dometic A/C heat pump last Summer. Had never use the heat output option until this fall. As mentioned, it needed to be around 40+ degrees to do anything. What's weird is that it blows nice and warm for awhile and then when it reaches the right temp if does not shut off but rather blows cold air for a while and finally shuts down. Then, just a minute or so later it starts back up and blows warm again.....repeat over and over.
Should be the defrost cycle causing that. Doug
