BTWHITISExplorerJan 09, 2014heat pumpI have a 2012 Bounder 35K. 2 air units. the rear air unit is also a heat pump, the front unit seems to be only air. Should both these units be heat pumps? The rear unit will put out heat, it seems...Show More
bullydogs1ExplorerJan 09, 2014Fleetwood has been known to do that..Call Fleetwood Customer Support and they can look up spec for you.
Related ContentHeat pump or propaneAc/heat pumpsheat pump questionSHURflo pump over heating....Heat Wrap Water Pump?
