slickest1
Jan 02, 2017Explorer
cbeierl wrote:
My Freightliner chassis has yellow shutoff valves for the cab heat water lines back near the engine. You might see if you have those and make sure that they are open.
Like said above or follow the heater hose up to the engine there may be a valve type tap that is shut off. The mechanic may of shut it off so the antifreeze would not leak out while changing the core and forgot to turn it back on.
38,767 PostsLatest Activity: Sep 19, 2016
