guygExplorerApr 10, 2017Heater ideasI've an E250 I've converted: insulation, fantastic vent, LED's etc., all nice. Where and when I go camping, sometimes a heater would be really nice. I've got a small electric for when I've shore power...Show More
RoyBExplorer IIIApr 10, 2017Have you considered to install a 6-gallon hot water heater...You might try this idea for a HYDRONIC HEAT source...Roy's imagethe heat exchanger could be one of these AQUA HOT 100/200 model...This would use the hot water in a closed loop only requiring minimal heating of the water using propane...Google ImageUsing a CAT type propane heater would be a hugh overkill for a small VAN setup...Roy Ken
Related ContentAtwood water heater problemReplace insulation inside heater column.Smelly Water HeaterWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???
