plambrinos
Sep 10, 2018Explorer
When the controls are off the heater will run and blow heat. when I turn the heaters on from the control panel everything works properly, example set the thermostat to 70 degrees and the heater will turn on until the temperature reaches 70 degrees then will turn of. it runs as it is suppose to but when I turn the heaters to the off position after about 1 minute the heater starts on it's own and will not shut off?
Could it be the electronic climate control module? I heard it chattering badly then stop.
Thanks for any help you can give me. https://cdn3.volusion.com/afvyg.fwnkv/v/vspfiles/photos/591-200-Intellitec-2.jpg?1517381651
