Busskipper
Apr 14, 2016Explorer
Mile High wrote:
I'm probably a little naive on this coming from a 5th wheel, but when rolling down the road with passenger is a class A, are you pretty much stuck with the generator running the whole time to cool behind the cockpit? Or will the inverter operate any of those 3 AC/heat pumps?
For the most part the Dash A/C will work as you drive down the road. (if you buy used that would be important to be sure the dash air still is GOOD - it is a weak point on many "A's") but if you need the Air on a day going across Utah or in the Foothills of Colorado you will need to run the Generator - we have found it uses maybe .6 gallons per hour so IMHO is not a factor.
Your Inverter is usually only sized to run the minimal Kitchen Micro or TV, unless you opt up to a larger 2,000 - 3,000 watt unit.
BOL on your search - you will find that it is Totally Different in a good way from the 5'er.
JMHO,
38,776 PostsLatest Activity: May 14, 2026
