Kayteg1
Apr 14, 2016Explorer II
2800 inverter sure sounds like big enough to run single AC, but is your alternator big enough?
Constant speed generators are known gas-guzzlers so running one is not very economical, unless you have inverter model.
Than taking 1 HP from the engine is not noticeable even on compact car, where in our cars we don't see mpg change from winter to summer, when AC is on 100% of the time.
Manufacturers don't wire AC to inverters as there is too much involved, but in my conversion, where I have 8000W alternator, I do run AC from inverter just fine.
Make sure inverter is having good cooling as that become small issue with mine.
38,776 PostsLatest Activity: May 14, 2026
