RayChez
Apr 14, 2016Explorer
The inverter will not run a AC or Heat pump. You have to run the generator.
And for those that say you can cool a big class A over 36' with the dash when it is 110 degrees outside. My answer is that they are dreaming. The dash will cool just in front, but the rest of the coach will get pretty hot. So that is when you fire up the generator to run both of your AC/heat pump which ever you need. In the winter I use the furnace instead of the heat pump if the temperature is below 34 degrees. The furnace will warm up the whole coach. Just set the thermostat at what ever you want inside the coach.
38,774 PostsLatest Activity: May 13, 2026
