Fla904ExplorerDec 03, 2015Heating RV problems.Does the RV ac unit also heat the RV? When I put the thermostat to heat it only blows out cool air? I'm a not turning something on?
21 RepliesReplies sorted by NewestShow MoreGrumpy374ExplorerDec 03, 2015The thermostat may be a generic that has a "heat" mode. But, does your ac unit have a heat strip? If not, then when you hit the heat function, it will only blow cool air, no heat.Grumpy
Related ContentTroubleshoot fridge problem...heat causing problems inside RVAtwood water heater problemNorcold Model 611 Fridge problemHeat Pump problems
