RambleOnNW wrote:
whemme wrote:
Sorry to say but all E rated tires of a certain size by any brand have the exact same max load carrying capacity when inflated to 80 psi.
Actually not. You can see from the Michelin load tables that the dual application of the C-Metric 225/75-R16C has 1000 lbs. more per pair or 2000 lbs. more per 4 rear tires at 80 psi. 5950 vs. 4940 lbs. per pair.
https://www.rvsafety.com/images/pdf/michelinloadandinflationrvtruck.pdf
But the Michelin 225/75-R16C is not an E rated tire. You are trying to compare apples to oranges.
