  • Hi Coolmom42,
    My specs for height and the REAL life were not even close. It is best to measure.
  • This Spec sheet shows height. You should not trust any spec sheets. It doesn't say whether it has antenna or AC which would add about a foot.
  • Usually. Check the brochure for your unit, if you can find a copy and check the specs section. They usually show each model's specs, with some sort of qualifying textual addenda about how they were measured.
