2bzy2c
Nov 15, 2015Explorer II
Here are the "big Items" you should pay attention to. These are the things that can let you down.
1. Tires - Don't trust tires over 7 years old. Look for the date codes. If you don't know how to read them simply Google tire date codes for help
2. Rubber - Hoses, belts, etc should be replaced. In particular upper and lower radiator hoses, and the heater hoses.
3. Cooling system. Have the radiator checked by a specialist. I can only assume the RV sat for long periods. The radiator is subject to clogging simply from sitting.
4. Brakes. Need I say more?
5. Obviously, the engine and transmission should be checked. Yes the RV only has 60K on it, but that engine and trans has been under constant stress moving that RV around. They tend to wear out faster than car engines due to the duty it has to perform.
6. Filters. Fuel, oil, air etc.
7. Batteries. You probably have three. If they have been sitting, they are probably at the end of their life cycle.
8 Refrig - Make certain it works. New ones (three way, gas, 12V and 110V) are very expensive. North of 2K from what I have heard.
Other than that, you should be good to go. Just expect lots of little things to go wrong. Hopefully, just annoying things. Have a tool box and a good attitude and you will be fine.
38,778 PostsLatest Activity: Jun 10, 2026
