Raymon wrote:
On my former 31 foot class C on a F450 Chassis I had an alignment, replaced OEM shocks with HD Bilsteins and installed a rear trac bar from Hendersons. I did only one thing at a time in that order so I would know which thing made the most improvement. The rear trac bar definitely made the most improvement; like night to day. Side winds were much easier to handle and so were oncoming large semis.
If I had installed the trac bar before replacing the shocks, not sure I would have changed the OEM shocks. The alignment was definitely needed. I cannot believe the motorhome manufacturers do not check the alignment after doing so many changes to the chassis. Wish you the best.
Ray
Glad to hear I'm on the right track !
