Jopopsy wrote:
Looks like I'm definitely going to be doing the rear sway. Still futzing w/ whether to do the front. All this is very helpful guys - much appreciated.
Just remember; there is a difference between sway bars and rear trac bars. Sway bars are usually installed front and back and are standard on most chassis. Trac bars are installed in the rear. A trac bar connects the frame to the axle. Trac bars are normally an after-market installation. Some people replace OEM sway bars with larger diameter bars which is purported to reduce sway. A trac bar helps the MH to travel a straight line down the road. Hope this helps.
Ray
