Racine96's avatar
Racine96
Hellwig sway bar
I just got a Hellwig 7718 sway bar for my Ford 450 MH. The instructions says that the bolts need to be tighten to torque specifications. However, it does not says what is that number for none of bolts. Do any one know what are these numbers? Where I can find them? Any help will be appreciated.
  • Mr. Google is your friend. Just search for torque specs for bolts and I'm sure you will find a table that will tell you exactly.
    Simple
  • j-d's avatar
    j-d
    Explorer II
    Since you say "7718" I imagine that your E450 is 2008 or newer, and the forward bolt on each cross member bracket is larger than the rear one. Is this correct?
    I so, I can tell you the torque for the rear ones, since front and rear were that size through 2007. But I don't have the fronts. And if you're asking about torque at end links to sway bar, I don't have those either.
    I've heard the front bolts on these are difficult.
  • There is a table of torques for bolt size if you google. I would call Hellwig first.
