luberhill
May 30, 2016Explorer
rgatijnet1 wrote:
There are many companies that will redo the windows. Cost is about $250 each in this area.
The roofing material is called Filon and is a fiberglass type mesh product. If kept coated, it will last decades.
Carpet is carpet. It will be stapled down so just yank it up and remove the staples. Install whatever flooring material you want after that.
So the roof should be coated ??? With what ??....the windows are a problem,,,no water but the seals are creeped in further than 1"....
So under the carpet Is probably plywood ?? Not aluminum ?
38,769 PostsLatest Activity: Apr 24, 2002
