DownTheAvenue
Aug 08, 2016Explorer
1. They probably just ran water through the system during de-winterization and you are seeing the residue with pink colored water. They obviously did a poor job. I am not sure why you would pay someone to connect your RV to a water source and turn on the faucets. You basically perform "de-winterization" functions every time you use the RV and its water system.
2. They probably did not damage your RV. If you see delamination, that is from water damage, not collision damage. If they had a collision in your RV strong enough to split a piece of interior wood, you would see crushed exterior damage. The area you say they damaged is probably rendered structurally unsound from water damage that you have admitted is in that area. Driving the RV on the highway has put stresses on that weakened area and things have shifted a bit causing what you see now.
