Hemi_RT
Aug 08, 2016Explorer
Delamination is from water getting in behind the outer fiberglass panel, it destroys the bonding in the luan (usually used behind the fiberglass)and allows the fiberglass to delaminate, it is NOT caused by an impact. Fiberglass gets crazing cracks all over the place and there isn't really anything you can do to prevent it, polishing the fiberglass helps some but will not fully stop it.
