JumboJet
Nov 18, 2014Explorer
GlennLever wrote:trop-a-cal wrote:
From the battery there is a relay to the starter that may be stuck. Sometimes just tapping it does the trick. Then there's the ground which may be wet and or rusted.
We cannot find this relay.
Not a ground problem as the starter works normal when the solenoid is jumped
Do you have to use the disconnect switch for the chassis battery to shut down the engine now that you have jump started it?
