charlie_good_ti
Nov 18, 2014Explorer
Remove small wire at starter---with 12v test light connect to wire you removed an other end to ground.Have someone engage switch to start an there should be currrent. If current soleoind is bad. If no current follow back to switch n see if switch is sending current to starter.Might be switch or bad wire from switch to starter.
