GlennLever
Nov 21, 2014Explorer
Tinstar wrote:Tinstar wrote:
Exact problem I had about 2 1/2 months ago ANd it was the "other" relay that caused my problem. I had 12 volts from of the ignition but "0" at the starter. After a couple of days crawling around, I found an unlabeled relay. Put a known good on in it's place and my problems were over. That relay was in a bay near the back of the coach where my fuel filters were. It was hanging by wires on the back wall of a bay. Wiring went from ignition, to this relay to the starter. I was about to wire a remote switch on mine too and there's nothing wrong with doing that until you can trace it down.
Just a thought. I forgot to mention; The "other" relay I found controlled the 2nd solenoid that activates the starter. No juice was going through that relay to activate the 2nd solenoid that activates the starter solenoid. Hope that makes sense.
It does, believe that to be the problem, just cannot fine it. Arrived home last night, currently 14 degrees outside, think the search will wait a bit.
