GlennLever
Nov 23, 2014Explorer
YC 1 wrote:
Different coach but mine has a similar panel hidden with a plastic cover. It is not in my battery compartment. It would be very close to the starter in order to keep the wires as short as possible.
Once you find the relay you should be able to solve the problem in about two voltage measurements. Do yourself a favor and once you find it don't tug and pull on things to see if anything is loose. Takes some voltage measurements in case it is just a loose connection. Then you will have some facts. Better yet, take a digital picture and print it out. Then write on the picture your readings. Keep for future use. Don't rely on your memory.
Will do, thanks
38,781 PostsLatest Activity: Aug 12, 2026
