Jim
Oct 10, 2018Explorer
You can also speed things along by getting an external pump at Napa. Used for decades by race cars they are as good as the internal. No need to remove the internal in most cases.
A local mobile RV tech should be able to install it. My diesel used an 8 GPM model. Required some brass plumbing to adapt the different port size to the hose size, and needed some new fuel hose, but Napa had all that. Worked fine for 12 years and never needed to drop the tank to get the old one out.
