TravelPilot's avatar
TravelPilot
HELP!! 97 5.7L DIES AT IDLE or DECELERATING???
I have a 5.7L in a GMC Van Converted to a Class B, it dies when idling, and when letting off the gas 3 times today. Then it takes a few tries to restart. This just started yesterday. I changed the Fuel Fiilter and put Octaine booster in with no luck. Could it be the fuel pump or what have you found it to be.
It sucked when it dies right in front on 2 cops and I blocked the whole turn lane :) Atleast no one could honk or get road rage with the cops there. They were even nice enough to wait til I got it started.
  • OP, you don't state, but if it has TBI, this kind of behavior is identical to an IAC (idle air controller) failure. You can run it all day long with the throttle plates open, but when they close the IAC fails to let in any air and the engine dies. It is a cheap easy fix, stop by an O'Reilly and pick up a new one. Clicky
  • Check for major vacuum leaks. This affects the ability of fuel pressure regulator to function (as well as the idle air controller).
    Once you rule that out, you probably need to verify fuel pressure. If you have never changed the fuel pump before, you'll probably need to.
  • RoyB's avatar
    RoyB
    Explorer II
    My FORD F150 did that once after I had the battery removed for an hour or so running some new cabling.
    I noticed right away the IDLE RPMs was low but there isn't any way to adjust this with the computerized vehicles. The manual said it should relearn the proper setting but for some reason mine wouldn't do that after a few days.
    I ended up having to take it back the dealership and let them reset the idle on their computer for $90 of course.
    Don't know if this is your problem or not - It did fix me up ok...
    Roy Ken
