Old-Biscuit
Nov 10, 2013Explorer III
Pickup a 3/4" PVC plug and screw it into the city water connection
The internal check valve inside the city water connection has failed....cheap plastic junk....just a plunger, sprig and o-ring. The o-ring gets out of position and the plunger doesn't seal.
Some have luck replacing the o-ring or getting it back in position but they are not worth the effort.
Plug it off.........use pump. Remove plug and use city water connection when you have it. Simple.
