pweekly
Jun 08, 2016Explorer
dougrainer wrote:
You add DEXTRON 3 to the HWH system. Do NOT add HYDRAULIC oil. The HWH system is separate from the chassis engine system. Do not add stop leak to the system, it will gum things up. If the jacks are inop now, that points to a problem that is more than just the genset problem. Doug
So you put transmission fluid in the reservoir? Sorry to be so stupid. :(
