dougrainer
Jun 09, 2016Nomad
pweekly wrote:
Ok. I did some more digging and the jacks went down ok, generator still won't budge, but I wiped up all the oil in the bay and then as the last jack finished going down, oil came spraying up from this hole by all the connections like a fountain. I have a video of where if anyone feels challenged or inspired to what to do. And if the hydraulic fluid (transmission fluid) is showing full and is pink, why is the oil everywhere in the bay, clear?
ORIGINAL HWH fluid is Dextron 3 without the red dye. So, some OEM's use the HWH fluid which is clear. When you top off the reservoir, you usually do not have access to HWH Fluid so you use the Regular Dextron 3 that will have the red dye. The reservoir has about 6 qts of fluid and you only use about 2 qts when extending the jacks and slides and such. So the leak is probably spewing the clear HWH fluid. Try to determine if the Leak is ONLY when activating the genset. If so, that is why it does not retract---The leak stops the force of the fluid from acting on the genset cylinder. DO NOT BEAR DOWN on the hose fittings(5/8 wrench). IF you overtighten it will break the fitting on the end of the hose and will really leak. The fittings are designed to just be slightly snug to seal. Doug
