wolfe10
Jan 14, 2018Explorer
In order:
Check water pump belt-- it is a separate V belt that ONLY drives the water pump. To check, lay under the rear, just to driver's side of centerline. Belt does not need to be bar tight, but not "flopping loose".
Next in line is to replace thermostat(s). Get that and gasket from a Caterpillar dealer using your engine serial number.
