Mr_Mark1
Dec 17, 2014Explorer
As I mentioned before, the Fleetwood has bays attached to the slide-out. Since you will be full-timing, you will have better under bay heat capability if you don't have the bays attached to the slide. When the Fleetwood slide is open, you can see under the whole coach and the weight of whatever you put in the Fleetwood holding bays is going to ride out with the slide. In my opinion, you will need pass-through storage.
I also think you will begin to love those extra cabinets in the bedroom as a full-timer. I'm not sure why you are concerned about the 'tightness' in the bedroom, you will be living in the front part of the coach.
MM.
MM.
38,782 PostsLatest Activity: Sep 02, 2026
