- Yankee770ExplorerSee the cover on the left
- Yankee770Explorer
- Yankee770ExplorerIts leaking sputtering our on the left side away from the plug. Behind a U shaped cover which i was trying to remove so i could see. I assume there will be a crankcase behind it that might have a bad breeather and gasket. Not sure of course. Ill get picture.
- wildmanbakerExplorerSo it is an 2002 MH, but we do not have enough information on what you removed the screws from. A picture would be helpful. Are you sure the oil fill plug is in tight?
