924guy
Jan 26, 2015Explorer
Traveler7 wrote:
If your setup is similar to my van conversion 'HOUSE' switch is used when you are connected to city power and takes 12 volt out of the circuit, activates the charger, and powers any 120 volt outlets you have. At least that's how mine works.....
Hope this helps and apologize in advance if I misunderstood you!
it is possible, but if so, then i have another problem as my 12v system will not energize with the switch in any position when . it only powers on when hooked into 120v (with the switch in either position,) or if i jump out the switching circuit by bridging the coil relay near the house battery.. very odd.
38,769 PostsLatest Activity: Mar 31, 2026
