Jim's avatar
Jim
Help finding drawer hardware requested...
I had my '02 Winnie Journey in for factory service and while there, tried to find the slide mechanism hardware for the tiny drawer on the drivers side nightstand. The slide device is only 8 & 3/4" long and Winnie no longer has any in stock with no plans to ever get that style again.
This picture is of the good side of the drawer, the other side the slide is crunched from getting trapped between the BR slide and the wall. That bent the metal enough that it's not reusable.
I'm looking for a replacement and haven't been successful finding anything. The original P/N per Winnie parts department is ATC RV 26222. (Perhaps I just haven't found the right search wording?)
I'm hoping someone on the forum has found a replacement device that I can order online. I'm in a small town and though there are 3 hardware stores, they carry a limited remodeling selection.
  • You noted that Winnie parts did not have that part, was it really Winnie or was it Lichtsinn? If you really contacted Winnie, you may want to contact Lichtsinn as they have a lot of obsolete parts. It is where I go for parts for my Adventurer.
    Make sure that the number you have was valid, I can't find anything for that number at all.
  • Finding an 8" drawer slide might be tough, 12" is usually the shortest. If you cut a 12" down to size the only thing you loose is the detente an the end that stops it from coming out. If you cut it from the front you would have to drill a hole and move the roller. I would cut the back of the track off and then install a small piece of wood at the top rear of drawer that stops the drawer from coming out.
  • That looks like the style they sell at Home Depot or Lowes. In the isle with the cabinet and drawer hardware.
