wolfe10
Oct 11, 2015Explorer
ATS is the likely suspect.
Turn off the main 120 VAC breaker in your coach 120 VAC breaker box. If it continues to buzz, you know it is in your ATS, as no power is going to anything else in the coach. This assumes you have eliminated your inverter/charger as the noise source. If not, turn it off so it does not invert when you turn off the main breaker.
