JRMunn
Feb 25, 2020Explorer
Bedroom Slide Problem
My 2004 Sunnybrook Titan 5th wheel bedroom slide will not close all the way anymore. For nearly a year, this trailer has been used mostly as a place to stay instead of for travel. Now I want to use it as intended and find that the queen bed slide doesn't close. The gap is less than 1/2" on the bottom and more than 1" at the top, which indicates that the slide is not "settling" at the end. At this point, the "gear" starts jumping and won't move the slide any closer. This may have been started by an overly long (standard queen size) mattress that hits the far side cabinetry before the slide closes. My solution has been to lift the mattress so it can slide over the top of the cabinet. This worked before, but not now. Because the mattress is both heavy and flexible, I haven't always got all of it above the cabinet. I can think of several possible causes. One is that trying to push against the mattress has worn down the slide gear teeth or enlarged the slots they push on. The other is that I am shifting the bed weight distribution (unloading the foot of the bed by lifting) in a way that affects the slide operation. And, finally, it might just need lubricating. But before tearing into it, I thought I would ask if anyone had found a solution to a similar situation.
JRMunn
JRMunn
