dougrainer
Oct 11, 2015Nomad
elhajj33 wrote:
Uh, false alarm. Tripped a breaker outside. Now to find that ATS. It's definitely not in the basement. It sounds like it's inside the breaker box and looking at where the wires come up from the inverter it would be there.
Seems strange that is have to pull the circuitr breaker panel to get to it.
Not unusual at all. Some RV's install the transfer in an overhead cabinet. Since you tripped a CG breaker---THAT points to possible BAD CG Electric system, causing your problem. Do not be so quick to assume your Transfer is the problem. Doug
