Executive wrote:
On a side note, unless you're boondocking, and it doesn't sound like you are, why do you have water in the fresh water tank anyway? I'd drain that knowing it's going to get that cold. I'm sure the water lines in the park are heated....best of luck. I hope it turns out to be a simple break in the water line. Shark Bite fittings at Home Depot are the best.....Dennis
I've found that most parks do not have heated water lines. Only a few times have we found them.
Just left a park yesterday with multiple spigots spewing water after they froze leaving no pressure and the city having a boil water advisory anyway. The park we moved to (450miles away) only has a boil water advisory.
So if the water goes out:
- If I have a full tank, I can continue for at least a few day.
- If I have an empty tank, I'm playing bottle water hunger games at the local walmart.
Of course, this presumes you have a means to keep the water tank from freezing.
