ghamblen
May 19, 2013Explorer
On our 6316 those heavy duty circuit breakers are mounted up high on the back wall of the compartment that contains the batteries, the slide motor and the slide reservoir. They are difficult to see unless you get down low enough to look up high on the back wall. There are four of those breakers. If they are tripped or if you press the reset button you will see a 3/4 inch black plastic lever pointing straight down from the bottom of the breaker. The word RESET is on the lever if you look closely. Carefully rotate this lever back up in to bottom of the breaker until you can't see the lever any more. The breaker is now reset and should be ready to go.
38,782 PostsLatest Activity: Sep 20, 2026
